Drivers missing after update to XLscore software
Postby CCuer » Sun Aug 04, 2019 1:23 pm
I am helping a friend with updating their new PC with the latest revision of the XLscore PRO software. After the update, sometimes when we run the program, all is fine, then other times (most of the time) there are no drivers or classes or race results. It is as if all the information has been deleted. What can I do to recover all the previous data? HELP!
Re: Drivers missing after update to XLscore software
Postby raceamerica » Sun Aug 04, 2019 1:42 pm
Now the program will look for driver information where they should be and Windows will not redirect the search. Your driver info will now appear correctly when you restart the software.
Postby CCuer » Sun Aug 04, 2019 4:42 pm
That did the trick! Now I am the hero who recovered the driver registrations and previous race results. Crazy Windows would add this type of file switching and not inform the user where the files will end up.
Postby raceamerica » Mon Aug 05, 2019 9:16 am
Something to remember in the future prior to installing an update, use the BACKUP function to save all your data. After the update (which may replace some files), use the LOAD function to reload all your data into the new software. Also remember to perform the above procedure prior to the LOAD of your data.
Users browsing this forum: Bing [Bot] and 2 guests
