Replacing Mil-spec plugs
Postby Rhyswaight » Fri Oct 17, 2025 7:38 pm
Hi,
I own a 2650 xl two lane drag system located in Australia. The connectors on the cables for the start line have been destored and our event is only a couple weeks away. I know they are mil-spec is there anywhere in Australia i can get replacement plugs im able to fit them myself but needing the correct plugs.
Rhyswaight
Re: Replacing Mil-spec plugs
Postby raceamerica » Fri Oct 24, 2025 9:53 am
What part number is on the cable you are referencing? And which connectors are you referring to since most 2650 cables have multiple different connectors?
You might contact support@raceamerica.com and send photos of the connectors.
